You can download XnView MP 1.8.6 here:
Windows x64 ZIP version SHA256: 4DE61AEC541A40AEFBF00C8C553CEB3564EF18956394F11481F7C4BFB780E7ED
Windows x64 SETUP version SHA256: 4D09F9EEB40A9D0B7E07E17831F3CE426BFBC722005FF2868D755B691CDF0631
Mac x64 DMG version SHA256: 563AA6484925C2B63C212000033F9E01BFE58B339896DAA507D2B285B232DCD3
Linux x64 TGZ version SHA256: 0F8300C8DE67A94F084DE8DDCD1380C030220F5BC0650E0BA8C53C027BC4C596
Linux x64 DEB version SHA256: BA791AEEF63FF6C2D7C4829861812222F42450812DE1731DBA83D8CFA3E0B84C
ARM version: https://download.xnview.com/XnViewMP-linux-arm.tgz https://download.xnview.com/XnViewMP-li ... _armhf.deb
Linux x64 AppImages version: https://download.xnview.com/XnView_MP.g ... 4.AppImage
Linux Flatpak version: https://flathub.org/apps/details/com.xnview.XnViewMP
Changelog 1.8.6:
3504: [New] Placeholder - replace word
3501: [New] Disable header scan in viewer - viewtopic.php?t=48506
3488: [New] JPEG-li in JPEG settings - viewtopic.php?t=47206
3506: [Bug] AVIF - color primaries - viewtopic.php?t=48182
3505: [Bug] Blurry image grey with cmap - viewtopic.php?t=46440
3503: [Bug] rating or label color number in place holder - viewtopic.php?t=48487
3502: [Bug] Theme in Settings - viewtopic.php?t=48447
3500: [Bug] Extra bottom space - viewtopic.php?t=48467
3398: [Bug] Windows - dav1d not used for avif - viewtopic.php?t=47936
3499: [Bug] Single Instance - focus not on image tab - viewtopic.php?t=48441
3399: [Bug] Viewer - greyed nav button after save as - viewtopic.php?t=47948
3498: [Bug] MacOS - create folder - selection - viewtopic.php?t=48501
3440: [Bug] Categories sorting - viewtopic.php?t=48126
3497: [Bug] Compare - viewtopic.php?t=48515
3496: [Bug] Batch convert - text - shadow - viewtopic.php?t=48492
3495: [Bug] Export - keep metadata settings - viewtopic.php?t=48464
3494: [Bug] JPEGXL - Keep metadata setting - viewtopic.php?t=47926
XnView MP 1.8.6
XnView MP 1.8.6
