Place holder
Locked
Place holder
In many places of XnView/XnConvert, you can use placeholder. A placeholder is between {}
Variables
All variables are between {}. You can cut a part of the text
• {variable [start-end]}
• {variable [start-]}
• {variable [-end]}
eg.
• {Filename} => img_example_105
• {Filename [0-2]} => img
• {Filename [5-]} => example_105
• {Filename [-7]} => img_exam
You can replace a word by another by using [~xxx~xxx]
eg.
• {Filename [~img~out]} => out_example_105
You can hide a variable if the value is empty: ((Model: {EXIF:Model}))
Date format
Date variable can be customized, by default system format is used.
• Y - Year
• y - Year without century (00-99)
• m - Month as decimal (01-12)
• d - Day as decimal (01-31)
• H - Hour (01-24)
• M - Minute (00-59)
• S - Second (00-59)
• B - Month name
• b - Abbreviated month name
• A - Weekday name
• a - Abbreviated weekday name
eg.
{Creation Date [Ymd-HMS]} -> 20211202-092920
{Creation Date [A B Y]} -> wednesday march 2021
EXIF variables
You can set an EXIF field by using his tag value, eg. {EXIF:x110}
Locked
