XnView 1.82 RC2
Locked
XnView 1.82 RC2
the second Release Candidate version of XnView 1.82 is available. First we had Alpha, Beta, and now Release Candidates (RC). On Wikipedia you'll find a good description of the various development stages. This Release Candidate should be of reasonable quality.
I hope that this RC2 is the last before final release!!
Important Notes:
+ Normal users should use the current Final version of XnView, which is version 1.80.3. Please see topic XnView 1.80.3 for details.
+ Download portals and websites must link to final versions of XnView only, and in no case link to this Beta version.
Download & Feedback
XnView 1.82 RC2 is available here.
At this stage I'd like get feedback for bugs (large and minor), or other comments regarding the added features. Thanks to report bugs, GPFs, or other problems found in the Beta. For further testing please make sure that you use this version (not an old beta).
All problems listed in group "Fixed in beta 4" are supposed to be fixed. If you have reported a bug and it is listed in 'Fixed in beta 4' please verify whether it has been really fixed.
Changes in XnView 1.82 are:
Added : "Thumbnails + labels" in view mode, and "show filename in thumb view" option
Added : Option SPACE => quickslide or dir next
Added : Switch mode => MiddleButton : nothing
Added : Adjust dialog => hide preview
Added : "Auto colapse last used folder"
Added : IPTC edit add "Time Created" and "Release Time"
Added : IPTC edit add "exif date taken, date digitized", System creation date/last modification data
Added : Options/Browser/Filelist/ ".."
Added : Camera RAW : full size, half size, ...
Added : IPTC edit in context menu (fullscreen)
Added : Send by Email
Added : Option : no scroll bar in view mode
Added : In properties, size in cm
Added : In quick slideshow, no adjust
Added : In fullscreen browser, add ctrl+b
Added : When picture is changed, and we delete it display "The file has been changed. Do you really want to delete the file?"
Added : auto levels/contrast in nconvert/multi cnv/toolbar(adjust)
Added : In "change timestamp", add/substract date/time from exif date
Added : Browser : change page from a multipage file
Added : Batch rename duplicate
Added : Support EXIF camera RAW
Added : hidden ini : OpenWithAssociatedProgram, OpenWithXnView, OpenNone
Added : option resize convert to make resize based on original orientation
Added : hanning filter to resize
Added : Write/File Type : most used to the top
Added : edit metadata/export in browser
Added : set jpeg lossless comment, comment <=> iptc caption
Added : Lossless clean : remove exif, iptc, thumb, ...
Added : BLP format
Added : convert in 32bits
Added : Sort by EXIF date (browser & batch rename)
Added : rotation anti alias + background color
Added : 'Name (Numeric)' in batch rename & web page
Added : thumbnail for text file
Added : deskew
Added : Thumbnails for folder
Added : PDF export
Added : Page Down/Up in filmstrip mode
Added : menu "File Edit View Image Filter Tools Windows" in view mode
Added : open bookmark menu with F6/Ctrl+F1
Added : Ignore extensions (separated by space) (par def PDF EPS PS EPSF)
Added : Message before saving multi page file
Added : Message before jpeg lossless rotation
Added : History of convert script
Added : When 'Single click to expand folder tree', do use underlined (treeview)
Added : ShellEx : Use embedded thumbnail if available
Added : ShellEx : EXIF rotation
Added : ShellEx : remove filename
Added : Add hotkeys Alt+2, Alt+3 ... for the second, third ... external program
Added : Add GridSpacing & GridType & KeepGridForNextPrevious as hidden ini
0 > No labels, 1 > Displays digits and letters for the X and Y coordinates (like actually), 2 > Displays only digits for X, and letters for Y
Added : F5 for refresh/reopen
Show/Hide Folder Tabs - Ctrl+Shift+M
Lossless crop - Ctrl+Shift+Y
Create Contact Sheet - Ctrl+T
Show/Hide Tabs - Ctrl+Shift+M
Added : PFI (photo Filtre Studio image)
Added : Folder Tabs, Status bar, Toolbar at the bottom in browser menu!!
Added : "Open parent folder" in context menu after a search
Added : EXIF-user-comment => comment
Added : Added View in search dialog
Added : ShellEx : Set as wallpaper -> fit-> best...
Added : Stretch video option in slideshow
Added : JBR import added
Added : Tab in batch convert
Added : Some entries in tab menu
Added : use_cie in NConvert for ghostscript
Added : option to replalce \ in filelisting
Added : Import wmz/emz
Changed : date template is "Y-m-d_H-M-S" by default
Changed : Use external EXIF text
Fixed : In Batch Rename, "Case" operation should be the last, currently it's before "Replace/With"
Fixed : batch rename: change <folder> to last folder not full pathname
Fixed : In copy/move dlg, hidden folder showed or not following option
Fixed : In fullscreen, view update after iptc editing
Fixed : Problem to rename a file after a searching
Fixed : Bad sorting after search/categories
Fixed : file size not updated after save
Fixed : tab icon not updated after next/prev
Fixed : bug to rename folder by changing only case
Fixed : Description not copied after drag&drop
Fixed : CRW orientation
Fixed : Add text (batch convert) position center
Fixed : ## in Web page create
Fixed : Zoom with mouse wheel in compare dialog
Fixed : Fix a bug for animated gif
Fixed : Problem slideshow in 95/98
Fixed : Problem when saving big picture
Fixed : playbar not hidden in view mode
Fixed : Softimage writing
Not all features suggested have made it into the new release. Reason are limited resources, please understand.
Thank you,
Olivier_G
Post by Olivier_G »
Thanks for RC2, Pierre.
I have a strange thing after replacing RC1 files with RC2 ones: the Thumbnails Cache doesn't recognize previous cached thumbnails.
=> Same Cache folder, still with all the previous caching files... but RC2 don't use them and replace them with new ones while Thumbnailing/Caching them... :(
Olivier
PS: I didn't experience this when doind so from Betas to RC1...
Olivier_G wrote:Thanks for RC2, Pierre.
Olivier
Yes, i have changed something in cache file to fix a bug
Olivier_G
Post by Olivier_G »
xnview wrote:Yes, i have changed something in cache file to fix a bug
OK. An update issue, but not a real bug in use...
(not that important in my case, but some people might want to know about it before losing their Cache)
Thank you,
Olivier
marsh
Post by marsh »
Fixed: Slideshow "all effects".
I counted 24 effects. Neat. :)
Locked
