1.8.5 - viewer - filelist - no autosort after saving
XnViewMP 1.8.5 64bit
Windows11 (24H2), display resolution 3840x2160, win scaling 150%
Viewer - filelist - sorting
0. prerequisites
  • have 2 files in folder (1.png (modified date: newer), 2.png (modified date: older))
  • set sort order in Browser to "newly modified files first":
    - Date (which is Modified date in reality, check 'Show Header' or switch to Details view)
    - Descending
  • ☐ or ☑ New files are added at the end of the list (it has no effect here)
1. open 2.png via double-click in win file explorer
file's index 2/2 - OK
2. press Ctrl+S to save image under same name
filelist will not be auto-sorted, file remain at 2/2
3. press Ctrl+R to reload image
filelist will be updated and file will be positioned at 1/2 - OK
expected behviour
filelist to be autosorted right after Save action (step2)
Related
