1.8.4 - The program does not see videos with extension *.ts
adrem85
Post by adrem85 »
Version 1.8.4 supports files with *.m2ts extension, but *.ts files are not seen or ignored - they are simply not displayed in the Browser. If I rename the file extension ts > m2ts, the file is immediately displayed in XnViewMP. This is a bit odd, as the *.ts extension is much more widely used than *.m2ts. Windows 11.
Re: 1.8.4 - The program does not see videos with extension *.ts
do you show all files? no exclude extensions?
adrem85
Post by adrem85 »
xnview wrote: Tue Feb 11, 2025 7:33 am do you show all files? no exclude extensions?
I recently installed the new regular version 1.8.5 and this problem is not there. Apparently it was also a bug related to the transfer of settings (xnview.ini) from the old 1.8.3 portable version to the 1.8.4 portable version.
Unfortunately, as it turned out in practice, transferring settings between portable versions when updating can cause unpredictable consequences and errors. This forced me to stop using the portable version of XnViewMP, since this application is updated quite often and customizing it manually each time is not the best option.
