icon bug with .heic files (1.8.4.)
golemus
Post by golemus »
Screenshot 2025-02-06 044500.png (4.39 KiB) Viewed 2205 times
This is what I see in Windows File Explorer (in 2 different computers) after updating to 1.8.4, blank icons.
Seems to be only with .heic files, .jpg, .png and .mp4 icons are ok.
Re: icon bug with .heic files (1.8.4.)
1. press 'Set file associations...' in Settings > Integration
2. set associations via Windows system settings or via SetUserFTA
3. (optional) rebuild icon cache
do you use the setup or zip package?
golemus
Post by golemus »
xnview wrote: Thu Feb 06, 2025 7:10 am do you use the setup or zip package?
the .exe file
please check the setup for 1.8.5?
golemus
Post by golemus »
Screenshot 2025-02-07 151112.png (2.75 KiB) Viewed 2079 times
1.8.5. seems to have fixed it. I am not sure though if the icon is same as it was 1.8.3. but I guess it is fine.
Stock
Post by Stock »
Bug still persists with XnViewMP 1.8.5 and .avif files.
They are blank. No icon.
avif no icon.png (8.46 KiB) Viewed 1866 times
Stock wrote: Tue Feb 11, 2025 1:38 pm Bug still persists with XnViewMP 1.8.5 and .avif files.
with setup?
yep, there is no avif.ico in FileIcons folder if installed via exe
right
Stock
Re: JPC icon missing in 1.8.6 exe x64
Post by Stock »
The avif file icon is fixed, but I got a new one to keep you entertained :mrgreen:
viewtopic.php?f=62&t=48594
