Enhance Colors window = Swap instead of Reset.
eil
Post by eil »
Enhance Colors window(called say from Adjust toolbar button) has lots of color adjusting scrolls and Reset button right next to each one. It would be much more comfortable, if those buttons wouldn't simply reset changes on corresponding scroll, but instead swap between default and user set numbers = first click - get default settings, second click - get back what changes were before "reset", and so on swap between 2 upon click.
Why? This will allow to easily and comfortably check how picture looks without one particular scroll-effect, and right back with it - yet that would be super fast and user wouldn't need to manually restore settings after each reset use.
Re: Enhance Colors window = Swap instead of Reset.
