Is there a way to reduce the borders under the pics (thumbnail view)?
FlyAway
Re: Is there a way to reduce the borders under the pics (thumbnail view)?
Post by FlyAway »
xnview wrote: Fri Apr 04, 2025 1:52 pm
FlyAway wrote: Wed Apr 02, 2025 9:30 am here the screenshot
https://postimg.cc/SJz4gDBg
Sorry but where is the problem?
don't you see all the gray icons? Wouldn't it be much nicer if they were colored? :)
For example the stars could be light yellow and if you select them it becomes dark yellow. The delete file icon could be green and red if you click on it... all the icons, in my opinion, should have a color and not be so anonymous
FlyAway wrote: Sat Apr 05, 2025 1:22 pm don't you see all the gray icons? Wouldn't it be much nicer if they were colored? :)
But the icons are greyed because they are disabled, select a file for example
FlyAway
Post by FlyAway »
sure, obviously... but in normal use they are gray. I use, and have used a lot of software and I don't remember one that has an interface, for the most part, gray. Maybe that's why those to whom I recommend Xnview and MP, tell me they prefer the first. The font is slightly different, I don't know how to explain it but if you enlarge the photo I posted, you'll notice it. The icons in Xnview are almost all colored... in Italy they say that "even the eye wants its part" :)
But the icons themselves, in my personal opinion, are not really beautiful, I don't understand that shade of purple and the icons are anonymous, they are cold.
Then mine is really a piece of advice on a trifle, your program is fantastic and you might find my criticisms ungenerous, I assure you that it is not so
thanks!
