1.8.3 - browser - metadata - sidecar - setting ignored for WEBP
XnViewMP 1.8.3 64bit
Windows11 (24H2), display resolution 3840x2160, win scaling 150%
Browser - metadata - sidecar
'Create/update XMP sidecar' setting ignored for WEBP
0. clean portable app
'Create/update XMP sidecar' is off
1. select test image (WEBP) in Browser
test_img_webp.zip
(700 Bytes) Downloaded 125 times
it has 3 categories that have been added via Edit XMP...
2. uncheck any category and press 'Update files from Catalog'
issue A
XMP sidecar will be created
expected behviour
embedded metadata should be updated and
no sidecar should be created, because 'Create/update XMP sidecar' is unchecked in Settings
issue B
sidecar created, but no sidecar overlay icon appears
Re: 1.8.3 - browser - metadata - sidecar - setting ignored for WEBP
This problem is supposed to be fixed in XnView MP 1.8.4. Please check and confirm the bug fix here.
fixed in 184
