Windows11 (24H2), display resolution 3840x2160, win scaling 150%
Viewer - auto zoom
Autozoom resets to 'No fit' from 'Fit to window, large only'
0. clean portable version
1. open any image
autozoom is set to default 'Fit to window, large only'
2. change zoom level, eg press +
3. press F11
4. press Esc to exit fulllscreen mode
5. press Esc to close app
6. open any image
autozoom will be 'No fit' (showing all images at 100% zoom)
expected behavior:
auto zoom to keep its default 'Fit to window, large only' state as I have not changed it manually to 'No fit'
Related
- issues
1.8.3 - viewer - auto zoom - resets to 'No fit' (current post)
- todo -
1.5.5 - viewer - pan - issues with selection/zoom/fullscreen
- done -
1.7.1 - viewer - auto zoom - fit image to desktop issues (1.7.2)
1.4.4 - viewer - auto zoom - mode inherits from fullscreen (1.4.5)
