Bug with folders
Xn User
Bug with folders
Post by Xn User »
Hi )
If I see files in first folder , and next without close XnView MP will be open files in second folders and next will presss enter for browse second folder , I will be remapped in first folder why ? https://www.mediafire.com/file/5l95s7zo ... g.avi/file
Re: Bug with folders
you means that browser is not in the folder of image when closing tab?
Do you have checked 'Settings>Interface>Select file in Browser..."?
Xn User
Post by Xn User »
Yes , this selected , but I have this bug , and I not known as fix this
https://www.mediafire.com/view/npin80j2 ... 1.png/file
I use XnView MP without tabs , but I think what this bug )
to reproduce:
1. run clean app, goto Settings
- check Allow only one app instance
- press OK
2. close app
issue A
3. double-click A.png in file explorer
A.png opens in Viewer - OK
4. press Return
Browser opens - OK
5. double-click A.png in file explorer
6. press Return
nothing happens
7. press Return again
Browser opens - OK
issue B
4. double-click B.png in file explorer
B.png opens in Viewer - OK
5. press Return
Browser will open A folder
issue C
4. press Return
Browser opens - OK
5. double-click B.png in file explorer
6. press Return
Viewer will switch focus to prev Viewer tab instead of opening Browser tab
Xn User
Post by Xn User »
But if press left Alt and enter, next close info, and next press enter, we will find ourselves in target folder )
This you can see here https://www.mediafire.com/file/r5l4vypm ... x.avi/file
I offer make so :
1) open file in folder 1 - In hidden mode, read the properties of the file
2) open file in folder 2 - In hidden mode, read the properties of the file
and so on ) then bug will be fixed )
I think, what need make automaticly read line and value Filepath , if I request properties XnView MP reading Filepath and that's why correctly open folder if I press enter
This problem is supposed to be fixed in XnView MP 1.8.6. Please check and confirm the bug fix here.
A,B,C fixed in 186
