Metadata entered in Category management is not displayed and not adopted
BSPicture
Post by BSPicture »
Dear all,
If I enter entries, e.g. keywords, in the “Category management” at the bottom of the screen, these are not transferred to the image file. Although the entries are declared as assigned in the category management, they are neither displayed under the preview images nor in the Windows file manager.
If I select images and go to Metadata -> Edit IPTC... and then make the entries, these are accepted and displayed both under the preview images of XnViewMP and in the Windows file manager.
Both procedures are described in the screenshots.
How can I write metadata (keywords, headings) to the files using the category management. This worked on my old PC... on my new PC with freshly installed XNViewMP this does not work :-(
Thanks for your assistance
Erik
Re: Metadata entered in Category management is not displayed and not adopted
Post by michel038 »
Hi Erik, you must first enable some "Export" options in Settings>Metadata before assigning categories to the photos... so that they will be saved as IPTC keywords and/or XMP subjects in photos.
For some raw formats, metadata can't be embedded, and they must be exported in xmp sidecar files (Settings> Metadata>Sidecar tab)
BSPicture
Post by BSPicture »
Thank you, that's it :-) The concept is a bit confusing for me... but the main thing is that it works now
