1.8.3 - View - Auto zoom changing
Sajan
Post by Sajan »
Seems, that when I change View - Auto zoom option (between "Fit image to window" and "Fit window to image"), this new option applies only on scrolling and opening another file or on XnView restart. But does not apply immediately. So, I open any image, go to Settings, change Auto zoom option, click OK on Settings dialog, and nothing changes (Viewer shows the image with previous Auto zoom option). And if I scroll to next file or close XnView and restart it, it shows the image with new correct Auto zoom option.
Re: 1.8.3 - View - Auto zoom changing
yes, each image tab has his own auto zoom setting. So you need to close/open the image tab
