1.8.3: Metadata / transfer for IPTC-IIM uncomplete (missing fields)
mokati
Post by mokati »
XnView: MP 1.8.3 - 64-bit
OS: Windows 10 - 64-bit
It's not a bug, but a uncomplete funktion:
"Metadata / TRANSFER "
Problem:
I want to edit /delete various iptc-metadata-fields.
but I can choose only a few fields at the "transfer-dialog" (yellow marked)
I want to wish do edit / delete all available fields which I can fill in at the "Edit IPTC-IIM" Dialog
Proposal:
to add the missing fields (pink marked) to the TRANSFER (IPTC-IIM) Dialog
Bonus: reorganize the sort by to alphabetical ;)
Re: 1.8.3: Metadata / transfer for IPTC-IIM uncomplete (missing fields)
This problem is supposed to be fixed in XnView MP 1.8.4. Please check and confirm the bug fix here.
mokati
Post by mokati »
Hello Pierre,
the most is fixed,
but I miss two entries, is it right ?
- content location code (from Source-tab)
- Job ID (from Status-tab)
right, reopened
This problem is supposed to be fixed in XnView MP 1.8.5. Please check and confirm the bug fix here.
mokati
Post by mokati »
now it is complete,
well done !
Thank you
