Transpcolor option issue [Solved]
koala76
Post by koala76 »
I try to remove the white background of a picture to make it transparent but the transpcolor option has no effect.
nconvert -out png -o temp2.png -truecolors -transpcolor 255 255 255 temp.jpg
Please see the example file in attachment.
Regards
SAMSAM
Re: Transpcolor option issue
Post by SAMSAM »
Try this:
-truecolors -set_alpha -transpcolor 255 255 255 -out png -o temp2.png temp.jpg
koala76
Post by koala76 »
Thanks, it works now !
