1.8.3: Batch convert - picture Resize in percent, unlogical
mokati
Post by mokati »
XnView: MP 1.8.3 - 64-bit
OS: Windows 10 - 64-bit
it is not a bug, but a unlogical option.
Problem:
to resize picture with the option "keep relations" i could select so on dimensions for width and height.
Proposal:
if I activate "keep relations" one field should be disalbled e.g. height (in Percent)
see picture.
masterjp
Re: 1.8.3: Batch convert - picture Resize in percent, unlogical
Post by masterjp »
I tested the batch conversion with these settings and the whole picture size get reduced to the smallest percentage.
I used 50% for heigth and 100% for width and the destination picture get a size of 50%.
I can confirm the error.
The program resize function works correct.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
This problem is supposed to be fixed in XnView MP 1.8.4. Please check and confirm the bug fix here.
mokati
Post by mokati »
the Problem is solved, perfekt,
thanks :D
