XnConvert 1.102
XnConvert 1.102
XnConvert (XnView batch convert as multi-platform standalone program) is available.
You can download XnConvert here
Windows x64 Setup
Windows x64 ZIP
MacOSX x64 DMG
Linux x64 TGZ
Linux x64 DEB
Linux x64 App2Image
Linux x64 Flatpak
MacOS APP Store
You can use
XnConvert file1 file3 file3
or
XnConvert @filelist
o-l-a-v
Re: XnConvert 1.102
Post by o-l-a-v »
The homepage is not updated with v1.102:
Which is used by package managers like Scoop to autoupdate the app manifest:
Are there other sources we can use to get informed of new versions of XnSoft applications? RSS? 🤔
Re: XnConvert 1.102
I believe XnConvert Home > About... also shows 1.101... :?:
And when I launched I received an invitation to update to '1.101'.
o-l-a-v
Re: XnConvert 1.102
Post by o-l-a-v »
I found here: https://github.com/SpecterShell/Dumplin ... Script.ps1
That there are also versioned downloads here: https://download.xnview.com/old_versions/XnConvert/
Which can be used to find out what version is the latest. I created a PR to Scoop to use this URL instead here: https://github.com/ScoopInstaller/Extra ... nvert.json
assybish
Re: XnConvert 1.102
Post by assybish »
The latest version doesn't show the before and after as this post shows in the graphics ! Why is that has the program been changed to stop this ? Nor does it show the button below the viewing screen to enable scrolling to the next photo to be processed. Win .64 bit version . What is going on ?
Re: XnConvert 1.102
assybish wrote: Sun Dec 01, 2024 4:56 pm The latest version doesn't show the before and after as this post shows in the graphics !
Looks as if you now need to click on the small icon below the Apply actions button at top[left...
That little icon really isn't very clear, at least on my screen.
You can step through loaded images using the button provided, are you saying that there was previously a mouse wheel step option?
assybish
Re: XnConvert 1.102
Post by assybish »
cday wrote: Sun Dec 01, 2024 5:37 pm
Thanks for your helpful reply .. seems like too much hassle on my laptop and like you say the icons are so small they are invisible. I have decided to revert to the 1.99 version .. not sure the later updates offer anything to make the loss of these features worthwhile ?
Such a shame as I have been with XnCovert for many many years now and loved it
Re: XnConvert 1.102
assybish wrote: Sun Dec 01, 2024 6:46 pm Such a shame as I have been with XnCovert for many many years now and loved it
It;s a pity that XnConvert versions have no change list, but realistically there is a limit to what one developer can do... :D
One change that I didn't like, and posted about at the time, was the addition to the Input tab of all the file info headings: they clutter what was previously a simple and attractive tab, and I generally have to expand the default Name field before doing anything else. I requested that their display be an option, ideally on the tab if that is possible, but otherwise on the Settings tab.
I don't know how that information can be useful on the Input tab unless check boxes are also provided to enable individual files to be selected.
Re: XnConvert 1.102
assybish wrote: Sun Dec 01, 2024 6:46 pm Thanks for your helpful reply .. seems like too much hassle on my laptop and like you say the icons are so small they are invisible. I have decided to revert to the 1.99 version .. not sure the later updates offer anything to make the loss of these features worthwhile ?
Why you don't like this button?
