Quick Filter searching through the displayed/configured data below every element
sx090
Post by sx090 »
Hey there,
I have folders of mixed elements from different sources, like IPhone, Android Phones etc.
Sometimes I want to quickly have a look at the elements captured by a specific model, e.g. IPhone 15.
The data is already there in my folder preview panel because I added / configured it to show up.
My question is: Is it possible to use the "Quick Filter" to search through all the shown fields for every picture (without the need to click the 3 dots "..." and do a thoroughly search which takes a while AND also displayes the search results differently)?
Would love to be able to search for the camera model here to quickly reduce the full folder view to only the matches:
Any ideas on how to activate it?
Or if not available, could this be added?
Re: Quick Filter searching through the displayed/configured data below every element
so you would like to quick search in thumbnail's labels?
sx090
Post by sx090 »
Yes exactly - and that obviously depends on user configuration anyhow. In my case, I see the camera model, so my usecase would be filtering these values.
But yes, generically spoken, the whole thumbnail label.
sx090
Post by sx090 »
Awesome, thanks, very much looking forward to it
This problem is supposed to be fixed in XnView MP 1.8.3. Please check and confirm the bug fix here.
sx090
Post by sx090 »
Perfect indeed - after enabling this option within the small dropdown:
I can easily search the configured labels, and therefore (my usecase) the smartphone model name... PERFECT, thanks so much!
chrisncy
Post by chrisncy »
ah super intéressant ! par contre, comment activer la zone quick filter ? j'ai bien essayé d'ajouter le filtre rapide dans la barre d'outil en mode explorateur, mais cela ne fonctionne pas...
J'ai du rater qq chose...
chrisncy
Post by chrisncy »
ok, j'ai trouvé ! désolée pour le dérangement
Parfaite cette option !
Post by michel038 »
Excellent !
Merci Pierre
Je pense que des utilisateurs vont peut-être passer à côté de cette fonction extra, elle est peu visible
Je suggère de la rendre active par défaut, car les options en menu déroulant avec la petite loupe, c'est vraiment discret.
Dommage aussi que ces options aient disparu des écrans paramètres...
