Exiftool doesn't display certain parameters anymore
toyotadesigner
Post by toyotadesigner »
The new version doesn't display certain parameters from my ARW files anymore.
Until recently, I could read following information:
Lens : FE 24-105mm F4 G OSS
Date Created : 2024:10:18
Aperture : 6.3
Lens ID : Sony FE 24-105mm F4 G OSS
Shutter Speed : 1/160
Focus Distance 2 : 2.015 m
Field Of View : 60.3 deg
Focal Length : 31.0 mm (35 mm equivalent: 31.0 mm)
Hyperfocal Distance : 5.08 m
Light Value : 11.6
Now the »Focus Distance 2« is missing. OK, I can use exiftool to view these parameters, but in older versions this had been a very comfortable way to check lens data…
hobbyists discuss new camera features
photographers discuss new software
masters discuss light
Re: Exiftool doesn't display certain parameters anymore
please post a sample file
toyotadesigner
Screenshot.
The ExifTool window shows only the »Composite« and »PrintIM Version«, nothing else.
a sample file please
with the TIF sent, i have EXIF fields in ExifTool panel
toyotadesigner
But as you can see in the screenshot, it is only part of the EXIF file in the panel on the left.
Re-install XnView? I don't want to damage my image database.
toyotadesigner wrote: Sun Oct 27, 2024 3:32 pm But as you can see in the screenshot, it is only part of the EXIF file in the panel on the left.
Could you post a screenshot with same tif file
toyotadesigner
with 1.8.2?
toyotadesigner
which macos version?
toyotadesigner
macOS Catalina
Version 10.15.7 (19H2026)
iMac (27 inch, Late 2013)
Processor 3,4 GHz Quad-Core Intel Core i5
Memory 24 GB 1600 MHz DDR3
exiftool 12.99 runs perfectly on this Mac, just in case you might think it won't work:
Last login: Sat Oct 26 09:45:23 on ttys000
designer@iMac ~ % exiftool -ver
12.99
designer@iMac ~ %
XnView runs with exiftool version unknown (it does not display a version at all)
I don't have anymore Catalina, but only Monterey, and no probleme here
1.8.1 works?
toyotadesigner
The last working version was from summer this year. I'll try 1.8.1 today.
toyotadesigner
Just downloaded and installed 1.8.1. Nope, same result as with 1.8.2.
However, maybe this helps:
When I start XnView 1.8.1 and select a TIFF, the Exif data are displayed, even the Exiftool version 10.98.
But as soon as I select a different TIFF, there are only 2 entries displayed in the panel: > Composite and > PrintIM.
When I select a third TIFF, there are different entries displayed: > Composite and > ICC_Profile
