1.8.2 - viewer - rendering - use gamma correction, use filter, antialiasing
XnViewMP 1.8.2 64bit
Windows11 (24H2), display resolution 3840x2160, win scaling 150%
Viewer - rendering
some image enhancement settings do not work together (Settings > View)
Issue A
'Use gamma correction' stops working if 'Use sharpen' is enabled
Issue B
antialising filters do not work with 'Use gamma correction' and 'Use sharpen'
Re: 1.8.2 - viewer - rendering - use gamma correction, use filter, antialiasing
Issue 'sharpen + filter' will be postponed
This problem is supposed to be fixed in XnView MP 1.8.3. Please check and confirm the bug fix here.
A - fixed
