Show Companion files not working as expected
I would like to view my jpg files and hide my raw files. I think I have things set properly in the setings but Xnview MP shows the raw files and hides the jpg files. What am I doing wrong?
Re: Show Companion files not working as expected
I don't know if there is a priority order by association lines but with the first line you associate the JPG files as a companion of the RAW files.
Thank you, that top line was already there by default. I will try removing it. I only added the last two raw extensions to the bottom line.
UPDATE: Removing the {raw} jpg line fixed it. It is working great now. Thank you very much, Franky.
