1.8.1 - viewer - selection - resizing when setting free aspect ratio
XnViewMP 1.8.1 64bit
Viewer - selection
1. open any image in Viewer
2. make any selection and release LMB
3. grab any corner point and start resizing to selection (do not release LMB)
4. press A (Free aspect ratio)
selection will resize to its previous size
5. drag corner for a few pixels more
selection will resize back to cursor position
expected behavior
selection should not resize when you change aspect ratio to 'Free'
Related
Re: 1.8.1 - viewer - selection - resizing when setting free aspect ratio
This problem is supposed to be fixed in XnView MP 1.8.3. Please check and confirm the bug fix here.
fixed in 183
