Webp file are opened in Browser Mode instead of Viewer Mode (settings are ignored)
Dret
Post by Dret »
Hi to all,
I would like to report a nasty bug.
I'm using XnVewMP Portable version.
Normally, when I click on an image file this is correctly opened into XnViewMP inside Viewer Mode.
But when I open a Webp file this one is opened into the Browser Mode, showing the folder instead of file and ignoring the settings in Option menu.
How can i fix this?
It's frustratin to search every time the right image in Browser Mode instead of the Viewer Mode! :(
Thanks in advance for support.
Bye.
Don't Panic!!!
Re: Webp file are opened in Browser Mode instead of Viewer Mode (settings are ignored)
from 1.4.3 - settings - integration - file association - add new ProgID:
  1. register app in the system
    • run XnViewMP with admin rights
    • press 'Set file associations...' (in Settings > Integration) to create ProgID keys in registry
    • make sure there is XnViewMP.webp key created in registry, eg:
      update path to match your case
      Windows Registry Editor Version 5.00
      [HKEY_CLASSES_ROOT\XnViewMP.webp]
      @="WEBP Bitmap file"
      [HKEY_CLASSES_ROOT\XnViewMP.webp\DefaultIcon]
      @="D:\\PROG\\portable\\graphic\\XnViewMP\\FileIcons\\webp.ico"
      [HKEY_CLASSES_ROOT\XnViewMP.webp\shell\open\command]
      @="\"D:\\PROG\\portable\\graphic\\XnViewMP\\xnviewmp.exe\" \"%1\""
  2. set associations
    • use any method to set associations:
      - windows 'Default apps'
      - windows 'Open with' context menu
      - 3rd party app, eg SetUserFTA
Dret
Post by Dret »
The keys in the registry are correct considering with the ones posted above.
I tried to use SetUserFTA without success.
Don't Panic!!!
Dret
Post by Dret »
Update:
I'm now using XnViewMp portable in a new PC (Win 10) and I have the same problem with .webp files.
Different systems, same problem: I don't think this can be related to a wrong file association (the keys are correct), it's seems something related to the app itself (maybe the portable version?).
Some ideas about?
Don't Panic!!!
It works here, which registry keys for .webp do you have?
Dret
Post by Dret »
The same posted above here (adapted to my path):
viewtopic.php?p=200807&sid=c05e3b6cd0ab ... 20#p200807
But the problem persist. :(
Don't Panic!!!
I've tried on a clean windows 10, and no problem.
What do you have in Settings>Startup?
Dret
Post by Dret »
1) Open with file > Viewer
2) Open without file > Browser
As you can see in screenshot
Don't Panic!!!
  • redo all steps from my post, try different association methods
  • run SetUserFTA.exe get > c:\associations.txt
    check txt file, what is written next to .webp?
  • post win registry export of XnViewMP.webp from HKCR (just in case, also check if HKCU it should be the same)
Dret
Post by Dret »
Point by point...
1) Result of SetUserFTA is: .webp, webp_auto_file
2) The export of XnViewMP.webp from HKCR is:
Nome chiave:          HKEY_CLASSES_ROOT\XnViewMP.webp
Nome classe:        <NESSUNA CLASSE>
Ora ultima scrittura:   15/10/2023 - 10:40
Valore 0
  Nome            <Senza nome>
  Tipo            REG_SZ
  Dati            WEBP file Bitmap
Nome chiave:          HKEY_CLASSES_ROOT\XnViewMP.webp\DefaultIcon
Ora ultima scrittura:   08/12/2024 - 11:13
Valore 0
  Nome            <Senza nome>
  Tipo            REG_SZ
  Dati            D:/SISTEMA/PORTABILI/XnViewMP/FileIcons/webp.ico
Nome chiave:          HKEY_CLASSES_ROOT\XnViewMP.webp\shell
Nome chiave:          HKEY_CLASSES_ROOT\XnViewMP.webp\shell\open
Ora ultima scrittura:   08/12/2024 - 11:14
Valore 0
  Nome            <Senza nome>
  Tipo            REG_SZ
  Dati            D:/SISTEMA/PORTABILI/XnViewMP/xnviewmp.exe
Nome chiave:          HKEY_CLASSES_ROOT\XnViewMP.webp\shell\open\command
Ora ultima scrittura:   24/09/2024 - 19:36
Valore 0
  Nome            <Senza nome>
  Tipo            REG_SZ
  Dati            "D:\SISTEMA\PORTABILI\XnViewMP\xnviewmp.exe" "%1"
3) Under HKCU I can't find a similar key. I only found, under "Software", the Xnview key with this value:
Nome chiave:          HKEY_CURRENT_USER\SOFTWARE\XnView
Ora ultima scrittura:   24/03/2024 - 15:08
Nome chiave:          HKEY_CURRENT_USER\SOFTWARE\XnView\XnViewMP
I hope this colud be usefull and thanks for support!
Don't Panic!!!
Dret wrote: Tue Dec 10, 2024 5:34 pm 2) The export of XnViewMP.webp from HKCR is:
you have D:/SISTEMA/PORTABILI/XnViewMP/xnviewmp.exe in ..\XnViewMP.webp\shell\open, it should not be there
not a big deal, but better to fix
1. select first XnViewMP.xxx key in HKEY_CLASSES_ROOT
2. and delete them all one by one
3. press F5
4. also check and delete if any XnViewMP.xxx keys remain in:
HKEY_CURRENT_USER\Software\Classes\
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\
5. repeat step1 from my post
Dret wrote: Tue Dec 10, 2024 5:34 pm 1) Result of SetUserFTA is: .webp, webp_auto_file
this is the issue, it should be:
you need to reassociate webp with app again
1. repeat step2 from my post, I suggest using SetUserFTA
ps. fyi, to export keys from registry - right click on key, press Export in context menu and save as .reg file (open with notepad)
Dret
[SOLVED] Webp file are opened in Browser Mode instead of Viewer Mode (settings are ignored)
Post by Dret »
Finally, it's done!
Thanks for patience and support!!! :D :D :D
Here’s a small summary for anyone who might need it:
- Download SetUserFTA.
- Open CMD as administrator and navigate to the SetUserFTA folder.
- Run the command:
- Open the "associations.txt" file created in c:/
- In the list of associations, there should be this value:
- If there is anything else, then run this command to correctly re-establish the association with XnViewMP:
SetUserFTA.exe .webp "XnViewMP.webp"
Don't Panic!!!
dmerces
Post by dmerces »
@user0, thanks for the valuable tips.
In my case I just add "%1" to the command line stored in the Context Menu setup.
It was "C:\Program Files (x86)\XnView\xnview.exe" and I changed it to "C:\Program Files (x86)\XnView\xnview.exe" "%1".
I've used the utility "Default Programs Editor" available in https://defaultprogramseditor.com
Everything works fine now!
Hope it can help.
