1.8.0 - viewer - scrollbars - zoomed image moves left
XnViewMP 1.8.0 64bit
Viewer - scrollbars
zoomed image moves left (if scrollbars enabled) on file change OR window resize
0. clean portable version
1. have 2 images in folder
test_img.zip
(2 KiB) Downloaded 72 times
2. open first image
- enable scrollbars
- set Zoom to "No fit"
3. zoom-in until both scrollbars appear, eg to 1600% (resize app window if required)
4. move image to the top-right corner
5. switch to another file OR resize app window slightly
image will move to the left for a few pixels
no such issue if scrollbars are disabled
Related
Re: 1.8.0 - viewer - scrollbars - zoomed image moves left
fixed in 181
