[EXIF] why xnviewmp choose EXIF instead EXIFTOOL?
manuel_songokuh
Post by manuel_songokuh »
hi
i love xnviewmp so much!
but i see xnviewmp use EXIF for insert information to setting>view>INFO..
but EXIF is poor information..so i check EXIFTOOL: proprieties have a lot information..
for this i want to ask you: "why" xnviewmp to use EXIF instead EXIFTOOL...???
what is version of EXIF...?
somethings not read exif to specially to file RAW: CR2 ( can read exif example: LENSID, but other RAW not read.. instead EXIFTOOL can read all raw...
for this reason i don't understand xnviewmp used EXIF to use it as feature..
please to Pierre , can reply here to explain, why chose EXIF instead EXIFTOOL..
i want to know why..
i love so much xnviewmp.. so i wish to care it ... :mrgreen:
Re: [EXIF] why xnviewmp choose EXIF instead EXIFTOOL?
EXIF is metadatas, Exiftool is not
Currently there is no way to use ExifTool output in Infos
manuel_songokuh
oh.. ok but why can't EXIF to show all metadatas...why EXIFTOOL shows many metadatas? i use EXIFTOOL is rich information..
so...dear pierre, i respect you all things, but in future: can you planner new feature for full metadatas (image, RAW..)please...
(what is version of EXIF used in xnviewmp 1.8.0..?)
Post by michel038 »
You can use Fastphototagger, it's a freeware, ExifTool based, in which you can choose any EXIF data (and iptc and xmp) that can be edited by ExifTool... It's not as smart as XnViewMp, but completely configurable.
It is able to handle all these chosen metadata in it's database
manuel_songokuh
michel038 wrote: Tue Sep 17, 2024 7:34 am You can use Fastphototagger, it's a freeware, ExifTool based, in which you can choose any EXIF data (and iptc and xmp) that can be edited by ExifTool... It's not as smart as XnViewMp, but completely configurable.
hi michel038
ok i try pastphototagger.. oh fastphototagger use EXIFTOOL...
i like xnviewmp but you can explain to pierre for new feature replace from EXIF to EXIFTOOL (like example that fastphototagger used EXIFTOOL)...?
xnviewmp is powerfully!!!
you can show custom field of ExifTool in Fastphototagger?
jamesmwphd
Post by jamesmwphd »
EXIF is limited, especially for RAW files like CR2. EXIFTool would give more details, but maybe they stick with EXIF for simplicity.
Post by michel038 »
You can show custom field of ExifTool in Fastphototagger?
This depends on what you mean by “custom field”
In Fastphototagger, the user chooses which fields to use, from the complete set of metadata that exiftool can offer.
You then check the ones you want to use in the database for queries, otherwise these fields will only be used for display or writing.
They must be declared in this table
And the first column can be edited (and translated) by user.
-Using xmp custom fields ( En Francais exemple 8 : https://orchisere.fr/logiciels/html/exi ... rsonnalise )
- Example using .exiftool_config file for exif makernotes : https://exiftool.org/forum/index.php?topic=5563.0 but that's beyond my capabilities.
manuel_songokuh
thank you so much!!!
manuel_songokuh
pierre: please can go to read topic:
topic
because maybe you did fix so can near code?
manuel_songokuh
hi
i do testing , checking.. but please can you explain me what did you resolve the bug?
for FIELD or EXIFTOOL version or EXIFTOOL add in info?
i checked but nothing..so i need information more from you okay?
manuel_songokuh
i read report of bug:
https://www.xnview.com/mantisbt/view.php?id=3344
pierre wrote: "Viewer info - ExifTool fields" so mean: add new FIELDS for exiftool.. but i check 1.8.1 results there is not FIELD for exiftool.. i use Linux maybe in windows will works? i go to check in windows a moment
manuel_songokuh
on windows 1.8.1 result nothing show FIELD for EXIFTOOL...
