1.8.0 - Error opening converted HEIC file
wagnervm
Post by wagnervm »
When converting some .jpg file to .heic using the program, Windows can no longer open the image. In previous versions this did not happen.
Re: 1.8.0 - Error opening converted HEIC file
i have no problem, could you post original file used?
wagnervm
Post by wagnervm »
Any jpg file I try to convert, this happens. The resulting heic file can be opened and viewed in XnView, but any other app on Windows can't open it, like Photos, Paint, Affinity Photos or any other.
no problem here on windows 10
wagnervm
Post by wagnervm »
I'm using Windows 11 24H2
wagnervm
Post by wagnervm »
wagnervm
Post by wagnervm »
They are already installed
send me a heic output sample file?
wagnervm
Post by wagnervm »
Of course!
Just remove the jpg extension from the file I added so the site accepts the upload.
wagnervm
Post by wagnervm »
Even so, the upload didn't work :/
wagnervm
Post by wagnervm »
I just did some more testing here, and if I set the conversion quality to any value other than 100, the conversion goes through successfully. It seems that the problem only occurs in lossless conversion.
wagnervm wrote: Sat Sep 07, 2024 6:53 am I just did some more testing here, and if I set the conversion quality to any value other than 100, the conversion goes through successfully. It seems that the problem only occurs in lossless conversion.
perhaps the windows HEIF extension doesnt support lossless file
