1.8.0: window drifts on switching between images
Lex-DRL
Post by Lex-DRL »
XnView: MP 1.8.0 - 64 bit
OS: Windows 10/11 64bit (also reproduced under Manjaro Linux)
When you switch between images with a hotkey (in the main "View" window) and images are smaller than screen size, the window itself slowly moves towards left-top corner of the screen with each image change, instead of staying in the screen center.
I have a few non-default settings enabled (though, I don't remember where they are in the settings window). Specifically, an option which tells XnView to resize the window to match the image size if it's smaller than the screen + an option which tells it to move to the center of the screen whenever image size changes.
I'm attaching my xnview.ini file.
Also, in case it might be important, I have 2 screens: first is 1080p with 100% UI scaling and the second is 4k with 125% scaling - both in Windows and Linux (in screen/display settings).
Effect: the window constantly moves across the screen (especially annoying when you switch between two images back and forth checking them for differences which might actually be just one pixel).
Expected behavior: it should either snap itself to one of the screen corners or position itself into screen scenter. Either way, it should stay in one place.
xnview.7z
ini config
(5.96 KiB) Downloaded 60 times
Re: 1.8.0: window drifts on switching between images
Lex-DRL
Post by Lex-DRL »
Seems fixed (I can no longer reproduce it in the same scenario I just tested it right before update).
