Image display direction is invalid
Every time after selecting a picture door in batches and changing the direction, the second picture always becomes invalid and must be reopened/refreshed to normalize.
Reproduce as follows:
1) Select multiple consecutive pictures in the browser
2) Press to turn left 90/right 90
3) Open from the first picture to full screen
4) Pressing the direction of the next picture (second picture) will be invalid.
5) The picture direction after pressing again is effective.
P.S. any version
P.S. any version
Re: Image display direction is invalid
That is, the direction has not changed and needs to be refreshed before changing.
sorry but i don't understand the issue, please post screenshots
To put it simply, after turning multiple pictures 90 degrees to the left, the second picture cannot be displayed correctly on the full screen(it needs to be refreshed to be correct).xnview wrote: Sun Sep 01, 2024 9:55 am sorry but i don't understand the issue, please post screenshots
i can't reproduce, the image files are rotated in browser and not in fullscreen?
After pressing the rotate key, the picture will change instantly in the browser, but the second picture will remain unchanged when entering full screen and needs to be refreshed to take effect.xnview wrote: Mon Sep 02, 2024 12:37 pm i can't reproduce, the image files are rotated in browser and not in fullscreen?
please send me samples files used? and your xnview.ini
The problem is the same with any JPG image. How to attach xnview.ini?
It should be possible in a ZIP, I think...alee001 wrote: Tue Sep 03, 2024 8:37 am The problem is the same with any JPG image. How to attach xnview.ini?
thank you for reminding.
- Attachments
- xnview.zip
- (10.37 KiB) Downloaded 153 times
ok, known issue please disable Settings>View>Misc - Keep current image
Thank you for your answer, that is the setting problem.xnview wrote: Wed Sep 04, 2024 2:29 pm ok, known issue please disable Settings>View>Misc - Keep current image
Is this option necessary or is the default better?
