Batch rename - widen Name template
XnViewMP 1.7.2 64bit
Batch rename - "Name template" control
few issues with control's width:
- is too short and its not possible to resize it manually
- its autowiden on dialog open, so if you have looong template - dialog looks weird
  • widen "Name template" control
    • A
      make border sizable
    • B
      move "Clear templates" button:
      1. below "Name templates" control
      2. to "Name templates" context menu
      3. to "Name templates" dropdown list
  • do not autowiden "Name template" control on dialog open
Related
Re: Batch rename - widen Name template
This problem is supposed to be fixed in XnView MP 1.8.4. Please check and confirm the bug fix here.
done in 184
