Quick filter on videos
eggsy.gs
Post by eggsy.gs »
I have been trying to get this to work for years with no luck.
I am trying to use XNView as a video library and just use catalog filter to navigate instead of folder structure. I am trying to use quick filter to filter the categories i have created but it just does it by file name no matter what i do.
I have it set to categoeries (catalog) in only in settings>browser>quick filter
and base path is default '\'
So to summarise
If i search rain while having the top category selected it selects anything with the filename rain and misses anything that i have "tagged" as rain.
Re: Quick filter on videos
on image files, it works?
eggsy.gs
Post by eggsy.gs »
I ran a test and it doesn't work for images either. I had just tested it on videos at that point.
what are your settings>Metadata & settings>Sidecar?
eggsy
Post by eggsy »
Here you go. Thanks for helping
please use latest version
eggsy
Post by eggsy »
I tried that but It didn't help :(.
Is there a setting there that can help?
eggsy
Post by eggsy »
Here is what i have now but i still doesn't search assigned categories :(
the assigned categories are written in catalog only or in embedded XMP? when you click on the file in browser, it shows you categories?
eggsy
Post by eggsy »
Sorry I am a little confused but i think its only the catalog.
When you say browser i am assume you mean in XnView? Its showed the little icon saying there is a catalog on the thumbnail while browsing the folder window
i can't reproduce, so you add a category on video file and put it in 'quick filter'?? please send us your xnview.ini
eggsy
Post by eggsy »
Sure. I can't figure it out.
I couldn't upload it direct so its in my google drive
https://drive.google.com/drive/folders/ ... drive_link
thanks a lot for looking into it
i have no access
eggsy
Post by eggsy »
Sorry i granted you access.
thanks again
with your .ini, i have a folder with 3 video files. I select one and apply 'cat1'. In quick filter, i enter cat, and i have the video file
