Is there a way to reduce the borders (thumbnail view)?
mrwul
Post by mrwul »
Is there a way to reduce the borders around the thumbnail view?
They take a lot of space.
Also is it possible to add a new label to be displayed below the thumbnail, like just the modified date.
SnagIt-18082024 160158.png (4.67 KiB) Viewed 4364 times
Thanks in advance!
Moderator & Librarian
Re: Is there a way to reduce the borders (thumbnail view)?
Does this do the trick, mrwul?
ToolsSettings…ThumbnailAppearanceThumbnail cellSpacing
mrwul
Post by mrwul »
Many thanks.
Regretfully that is already set to the lowest value: 0
So, in my example above, the thumbnail on the left, that is already set to zero.
Example: if you have shot something 'developing' (1-2 shots each day) you may want to use the thumbnails to show a kind of 'collection', say maybe 6 thumbnails on a row, instead just 3
Bad luck.
Thanks anyway.
mrwul wrote: Sun Aug 18, 2024 2:04 pm Is there a way to reduce the borders around the thumbnail view?
which size do you use?
mrwul
Post by mrwul »
Settings are as follows:
SnagIt-20082024 152325.png (11.2 KiB) Viewed 4231 times
SnagIt-20082024 152528.png (10.15 KiB) Viewed 4231 times
making thumbnails almost borderless saves a lot of space
you ask for a square thumbnail 96x96, and your files are portrait so there is some space around
mrwul
Post by mrwul »
Okay, good point. I didn't look at that.
Just checked, when I reduce thos numbers, size remains the same.
mrwul wrote: Tue Aug 20, 2024 3:09 pm when I reduce thos numbers, size remains the same.
you have changed "Custom thumbnail size"
now select it in Browser tab > View menu > Thumbnail size
Post by michel038 »
At the top of browser, there's a slider to adjust size or number
of displayed thumbnails.
To toggle [size of thumbs] or [number of thumbs] , use the small button near the slider ; then adjust number or size with the slider.
But if you have portrait and landscape photos, some space will be lost , because the browser can't adjust width and height for each photo.
mrwul wrote: Tue Aug 20, 2024 1:39 pmmaking thumbnails almost borderless saves a lot of space
Older request(s):
mrwul
Post by mrwul »
Something like this then?
