wrong ISO values
BonChi
wrong ISO values
Post by BonChi »
Today I noticed, that the ISO values in EXIF section are wrong. On my Digital Camera Sony Alpha 7 RV I have the ISO 102.400 in EXIF data in XNView the value is 65.535. It seems these discrepencies occur for all ISO values >65.535.
Please check it and fix it. Todays cameras can a lot more than 65.535 ;-).
I am using XNView MP 1.7.2 64bit.
Greetinx BonChi
Re: wrong ISO values
please send a sample file
BonChi
Post by BonChi »
https://drive.google.com/drive/folders/ ... sp=sharing
Here is a picture with ISO 102.400. I notices, after copying to my HDD, Windows shows in the properties for this picture also ISO 65.535.
ISO field contains 65.535, ExifTool shows this value too
BonChi
Post by BonChi »
Ok, I wonder what's the matter, the file was not modified by copying to the HDD, and look at this picture, what my camera is saying:
BonChi
Post by BonChi »
Hi Pierre,
I tried the following: I copied the picture which is linked above back to my camera using another file name. I selected the picture on my camera and looked into EXIF data, and there are again 102.400. That means, that the correct ISO value is in the file, but Windows ignores that and makes the highest possible value out of it.
Using other picture viewers they also show ISO 65.535.
BonChi wrote: Sun Aug 18, 2024 12:31 pm I tried the following: I copied the picture which is linked above back to my camera using another file name. I selected the picture on my camera and looked into EXIF data, and there are again 102.400.
with which app?
BonChi
Post by BonChi »
No App, using the firmware of my camera.
BonChi wrote: Mon Aug 19, 2024 1:54 pm No App, using the firmware of my camera.
ISO is saved in another field (Makernotes) i think
BonChi
Post by BonChi »
I am afraid I can not help you with that. If I use the Sony software for reading out EXIF data, the field is called ISO. I guess the internal name could be the one you mentioned.
how it looks in other apps
'Recommand exposure index' is shown as 102400 in Xn
