1.7.2 - batch rename - few issues
XnViewMP 1.7.2 64bit
Batch rename
few issues
issue A
  • alignment - controls should not stretch vertically
issue B
  • drag&drop from win explorer
    - file counter in title does not change when you add files via drag&drop
    - you can drag&drop folder that will lead to the error during renaming
issue C
  • files reorder functionality
    0. have some files in the list (~10)
    1. select 3 files
    2. use ▼▲ to move them from top to bottom and back
    sometimes only one file (out of 3) will be moved
Related
Re: 1.7.2 - batch rename - few issues
This problem is supposed to be fixed in XnView MP 1.8.0. Please check and confirm the bug fix here.
fixed in 180
