1.72 - batch conversion log file - removing textparagraph (empty lines)
masterjp
Post by masterjp »
Yesterday I looked into my batch conversion log file. It was very long.
Most of the first area the batch conversion was skipped, because the destination files already exists.
Is it possible to remove the textparagraph between the lines?
The log files will get much shorter and you have a better overview.
Log file example:
Started at: 30.07.2024 20:48
E:\Digicam\Amsterdam2024\001.jpg : skipped, file already exists!
E:\Digicam\Amsterdam2024\002.jpg : skipped, file already exists!
E:\Digicam\Amsterdam2024\003.jpg : skipped, file already exists!
Better:
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
Re: 1.72 - batch conversion log file - removing textparagraph (empty lines)
I don't like the selective usage of separator (grouping) in this case as it will look untidily when mixed with other states.
The entries separator (empty string) should be applied to all entries or not at all.
