XnConvert 1.000 ZIP download reports missing Qt DLL
Attempts to launch XnConvert 1.000 ZIP version result in an error message that Qt5Widgets.dll was not found.
Re: XnConvert 1.000 ZIP download reports missing Qt DLL
i have no issue with zip package, windows 10?
xnview wrote: Mon Jul 01, 2024 12:04 pm i have no issue with zip package, windows 10?
Yes...
i've tried on another win 10, and no problem. Qt5Widgets.dll is in the ZIP
xnview wrote: Tue Jul 02, 2024 7:41 am i've tried on another win 10, and no problem. Qt5Widgets.dll is in the ZIP
And if you launch xnviewmp.exe, no missing-dll warning displayed?
Could xnviewmp.exe possibly be finding it somewhere else on your computer?
cday wrote: Tue Jul 02, 2024 8:02 am And if you launch xnviewmp.exe, no missing-dll warning displayed?
Yes
how that? you start it from folder of ZIP?
Sorry, just about to correct xnviewmp.exe to xnconvert.exe... :wink:
Launched using a shortcut to the executable file in the unzipped folder...
Not sure whether if a required dll isn't found in the folder, the exe might look elsewhere on the computer, and possibly have found it on your computer but not on my little-used W10 install?
cday wrote: Tue Jul 02, 2024 9:04 am Not sure whether if a required dll isn't found in the folder, the exe might look elsewhere on the computer, and possibly have found it on your computer but not on my little-used W10 install?
Qt5Widgets.dll is in the package
Downloaded again yesterday, extracted, and launched without issue, previous issue of reported missing Qt DLL unexplained... :?:
