App UI - menu structure - View - improve channel commands
XnViewMP 1.7.2 64bit
App UI - Viewer/Browser - View/Preview menu
lack of items grouping and channel show/hide functionality
Viewer
  • add 'Show channel' group
  • rename
    to clarify functionality and consistency with terminology of other applications (see examples)
    • High zoom quality →
      Use anti-aliasing
      also rename in Settings > View
Browser - Toolbar / Context menu
  • unify Zoom/Navigate groups position
    it is more or less ok to put these items in one group (w/o separator between them), but
    Navigate should be first, since its related to Open commands above
  • (optional) add same Antialiasing and Transparency grid commands as in Viewer
    with Browser's own state
Browser - Context menu
  • (optional) remove File operations commands
    what is the reason to perform file operations from Preview menu?
Example
  • antialiasing / transparency grid
Related
Re: App UI - menu structure - View - improve channel commands
This problem is supposed to be fixed in XnView MP 1.9.0. Please check and confirm the bug fix here.
done in 190
