Banner - improve hint
XnViewMP 1.7.1 64bit
Banner
hint html/wording can be improved
<html><p>All banner specifications (font, color, size, etc.) carry forward from the previously created banner. An exception is text size, which is calculated to 'Best fit' for banner height.</p><p>You may select multiple images to apply the same banner to several images at once. Note that the text will be the same size in all images, then.</p><table border="0" cellpadding="0" cellspacing="0"><tr><th colspan="2" align="left" style="border-bottom:1px solid gray;padding-top:15px">Shortcuts</th></tr><tr><td>Ctrl+Plus/Minus</td><td style="padding-left:15px">Increase/decrease font size by 2 points</td></tr><tr><td>Ctrl+Shift+Plus/Minus</td><td style="padding-left:15px">Increase/decrease banner size by 1%</td></tr><tr><td>Ctrl+S</td><td style="padding-left:15px">Start banner creation</td></tr></table></html>
Re: Banner - improve hint
This problem is supposed to be fixed in XnView MP 1.8.3. Please check and confirm the bug fix here.
done in 183
