Settings - metadata - add high level rw options
XnViewMP 1.7.1 64bit
Settings - metadata
managing metadata is not clear enough
Note1: Edit XMP/IPTC dialogs' functionality do not depend on Settings>Metadata and not reviewed here.
Note2: splitting Companion files/Sidecars settings into 2 tabs is a bit odd, since Sidecars is a subset of Companion files. However, I'm not sure if/how they should be combined yet.
Suggestion - WIP
  • add high level read/write options for metadata
    on high level - what to do
    on low level (at individual tabs) - how to do
    • existing Metadata tab
      - rename tab → IPTS & XMP
    • Sidecar tab
      - move 'Update or create XMP Sidecar' to new tab
  • add Read order
    since there are multiple sources to read, explicit order could be useful
    - maybe add some message that there are some conflict data between different sources
Example
  • Adobe Bridge, CameraRAW, Lightroom
  • digiKam, CaptureOne
cicciobello
Re: Settings - metadata - add high level rw options
Post by cicciobello »
Good! About "Read order", I think that "Mockup A" is better.
