1.7.1 - settings - metadata - Automatically apply parent category - Ctrl+click is ignored
XnViewMP 1.7.1 64bit
Settings - metadata
0. clean portable version
1. goto Settings
- check ☑ Automatically apply parent category (Ctrl+click for single category)
- press OK
2. open Browser tab
- select any image
3. goto Categories pane
- Ctrl+click on any subcategory to assign it (eg Animals)
parent category (Photographs) will be assigned as well
expected behaviour
only one, current cat (Animals) should be assigned
  • rename
    Automatically apply parent category (Ctrl+click for single category) →
    Automatically assign parent Category (Ctrl+click for current only)
    its better to
    - always capitalize metadata terms (Rating, Color label, Keywords, Category)
    - use 'assign' over 'apply' for metadata
    - avoid repeating
Re: 1.7.1 - settings - metadata - Automatically apply parent category - Ctrl+click is ignored
user0 wrote: Sat Apr 27, 2024 7:13 am
expected behaviour
I don't understand, if setting is checked, category's hierarchy is selected
I'm refereeing to the bracketed part of of the setting - (Ctrl+click for single category)
maybe I'm missing something, but my understanding is that
this should change the default behavior of this feature (when the feature is enabled), for example:
  • LMB click
    click on child -> assign child AND parent(s)
  • Ctrl+LMB click
    click on child -> assign only child
Otherwise, what is the intent behind the text "(Ctrl+click for single category)"?
This problem is supposed to be fixed in XnView MP 1.7.2. Please check and confirm the bug fix here.
fixed in 172
