Browser - shortcuts - fix Open containing folder
XnViewMP 1.7.1 64bit
Browser - shortcuts
CTRL+O shortcut for 'Open containing folder' (file context menu + ☑ Show files in subfolders)
never worked as it always conflicted with Open/Open... command
  • fix shortcut for 'Open containing folder' (cmd_openContainer) in Browser mode
    • remove shortcut completely
      since it's rarely used
      OR 
    • maybe change shortcut to CTRL+SHIFT+O
      But I think there are much more useful commands that could potentially take advantage of this shortcut, eg 'Open in file explorer'
Related
Re: Browser - shortcuts - fix Open containing folder
This problem is supposed to be fixed in XnView MP 1.7.2. Please check and confirm the bug fix here.
fixed in 172
Scargoth
Post by Scargoth »
:( L'ouverture du dossier contenant se fait bien avec Clic-Droit, mais pas avec Ctrl+O, ni Ctrl+Maj+O
1.7.2.64 + Windows 10
Scargoth wrote: Tue Jun 18, 2024 2:10 pm :( L'ouverture du dossier contenant se fait bien avec Clic-Droit, mais pas avec Ctrl+O, ni Ctrl+Maj+O
Oui Ctrl+O est maintenant pour 'File>Open...', vous avez la touche entrée pour ouvrir un dossier, ou sinon vous pouvez ajouter le raccourci
