XnView MP Option - Fit image to desktop, large only
app crash
to reproduce
0. clean unzipped version
1. open image in Viewer
2. set "Fit image to desktop" OR "Fit window to image" (View > Zoom)
nothin happens
3. scroll to the prev/next image OR press -/+
app will crash
dump.zip
(25.04 KiB) Downloaded 88 times
ps: my resolution 3840x2160 (4k), 150% win scale
Re: XnView MP Option - Fit image to desktop, large only
This problem is supposed to be fixed in XnView MP 1.7.1. Please check and confirm the bug fix here.
fixed in 171
jsin
Post by jsin »
No jittering and the fit to desktop seems to be working again!
jsin
Post by jsin »
I noticed that in 1.7.1, the window still shows gray borders (padding) around some of the images, but not all of them. It doesn't seem to completely shrink itself to completely fit the image like Classic does.
I also noticed that when I have an image opened in MP that the window will not resize itself and jumps around when I try to grab and drag the window smaller. I will PM you the link to the folder I have comparing the differences between MP and Classic for the same images.
jsin wrote: Tue Apr 09, 2024 1:15 pm I noticed..
1.7.1 - viewer - auto zoom - fit image to desktop issues
