Change Timestamp doesn't set EXIF: Date taken, even if "create" & "force" are checked
metal450
Post by metal450 »
I have some jpgs where, if I use Tools->change timestamp, select "create EXIF metadata if needed," also select "force the update in case of anomaly", and select "EXIF: Date taken", it doesn't apply the date. It also doesn't report any error - it just does nothing (i.e. silently fails). I'm setting to a fixed time.
Here are a couple examples:
https://www.dropbox.com/scl/fi/gry9lbv4 ... j355m&dl=0
https://www.dropbox.com/scl/fi/tq98n1l7 ... h1zj3&dl=0
Re: Change Timestamp doesn't set EXIF: Date taken, even if "create" & "force" are checked
ExifTool returns an error on these files "Error reading StripOffsets data in IFD0"
metal450
Post by metal450 »
If there's an error, the UI should show the operation result as an error - rather than just silently failing & making it look like the operation was successfully performed on all files
This problem is supposed to be fixed in XnView MP 1.7.1. Please check and confirm the bug fix here.
metal450
Post by metal450 »
Confirmed
dandv
Post by dandv »
I still see this problem in v1.8.3 with any JPGs I've tried from my smartphones.
exiftool doesn't report any problems, but after going to to Metadata -> Change timestamp and entering a specific timestamp and checking all 6 checkboxes, the timestamps remain unchanged:
Create Date : 2024:11:21 16:31:02.186
Date/Time Original : 2024:11:21 16:31:02.186+08:00
Modify Date : 2024:11:21 16:31:02.186+08:00
