I have been systematically tracking handle leaks. And since RC1 is out I think it's right time to give the results. All of these don't necessarily are real leaks.
Heres what I have found:
==> http://newsgroup.xnview.com/viewtopic.php?t=4640
- Options / Toolbar / Skin page leaks GDI handles (when you close options window some GDI handles aren't released)
- JPEG Lossless Transformations window leaks two GDI handles for every run
- About window leaks two GDI handles for every run
- Every browser tab leaks GDI handles for every run (close and restart browser)
Edit: This probably isn't a real leak.
- Every image view tab leaks one handle for every run
Image view tabs don't leak if the browser is not open, but when it is open, one handle leaks every time when you close the tab. So the real leak probably is in browser (Thumbnail is updated after you close the view? And one handle leaks?).
RC1: Possible small handle leaks
When you close the About window are the GDI handles released?
If they are, there isn't a bug.
My Test 1:
Load XnView and Process Explorer
-> GDI Handles for XnView are 148
Open About Dialog
-> GDI Handles for XnView are 152
Close About Dialog
-> GDI Handles for XnView are 150
Conclusion = possible small leak.
My Test 1:
Open About Dialog
Close About Dialog
Yeah you are right. Oh my fault. Look the first post I fixed it. Sorry.ckit wrote:Conclusion = possible small leak.
By the way how you overline text in this forum? , [strike] or [overline] don't work.
It's disabled by default as a security measure:
BBCode Strike
http://www.phpbbhacks.com/viewhack.php?id=444
BBCode Strike
Re: RC1: Possible small handle leaks
Not sure that it's a leak...ckv wrote: - JPEG Lossless Transformations window leaks two GDI handles for every run
- About window leaks two GDI handles for every runRight- Every browser tab leaks GDI handles for every run (close and restart browser)
Image view tabs don't leak if the browser is not open, but when it is open, one handle leaks every time when you close the tab. So the real leak probably is in browser (Thumbnail is updated after you close the view? And one handle leaks?).[/size]
