Rating automatically canceled
alee001
Post by alee001 »
When I filter out the photos with a score (1 to 5), every time I crop, edit and overwrite the photos, the score is automatically canceled and needs to be re-marked. Is there any need to improve?
Re: Rating automatically canceled
rating is removed for the file? Please describe more the issue
JongHo
Post by JongHo »
I have experienced same problems. When a image is edited in XnView, the rating is removed in browser.
alee001
Post by alee001 »
xnview wrote: Wed Mar 13, 2024 8:14 am rating is removed for the file? Please describe more the issue
After any changes are made to the image and the file is saved (in XnView), the original mark rating will be automatically cancelled.
could you describe the way to reproduce?
alee001
Post by alee001 »
xnview wrote: Sat Mar 30, 2024 3:34 pm could you describe the way to reproduce?
Simple example:
1) Mark a JPG image as 5 stars (Ctrl+5)
2) Double-click the image to enter editing mode
3) Select Curve/Crop
4) Any changes
5) The result is the image tag
6) Select Save (S)
The 5-star mark of this JPG image is automatically cancelled.
ckit
Post by ckit »
alee001 wrote: Sun Mar 31, 2024 5:09 am
Simple example:
4) Any changes
6) Select Save (S)
Confirmed
do you have the setting to store rating in XMP metadata?
alee001
Post by alee001 »
xnview wrote: Tue Apr 02, 2024 1:08 pm do you have the setting to store rating in XMP metadata?
The settings are as follows, are they correct?
This problem is supposed to be fixed in XnView MP 1.7.1. Please check and confirm the bug fix here.
alee001
Post by alee001 »
xnview wrote: Mon Apr 08, 2024 2:36 pm This problem is supposed to be fixed in XnView MP 1.7.1. Please check and confirm the bug fix here.
One more thing, please follow up. If the image has been rating, if you change the format later (such as converting from PNG to JPG), the rating will be automatically removed.
alee001 wrote: Tue Apr 09, 2024 1:32 pm One more thing, please follow up. If the image has been rating, if you change the format later (such as converting from PNG to JPG), the rating will be automatically removed.
you need to save the rating in the metadata of files
