remove button in actions and live preview of actions in input tab
estatistics
Post by estatistics »
1st picture - actions
When you press CTRL + U it appears the Batch convert menu.
I have many photos that i manipulate the same time.
1) However, some photos when i review them, eg. dont need crop. an "X"-remove button is missing from viewer.
I must do that in 2nd step by going to "input" tab.
2nd picture - input files
2) It will be very helpful to see the "actions" live to all selected pictures. However sadly, this is not happening.
Re: remove button in actions and live preview of actions in input tab
1. what is the problem with standard file selection shortcuts?
- have files selected in Browser
- hold CTRL+click LBM to unselect/select any file
- press CTRL+U
2. just do multiple converts until you're happy with the result
estatistics
This is not very quick if you have 1000+ files.
In actions, you can preview files. It is better to decide instantly if you like the image to nbe converted instead of making additional steps to unselect it.
--- also going with "arrows" one by one in preview is very slow. An additional slide bar will be very helpful too.
estatistics wrote: Tue Mar 05, 2024 4:48 pm 1) However, some photos when i review them, eg. dont need crop. an "X"-remove button is missing from viewer.
so a 'remove from file list'?
estatistics
xnview wrote: Sun Mar 10, 2024 1:25 pm
yes exactly.
estatistics
Thanks! Fixed!
