2 x 'Adjust' context menus (almost identical)
rotbus19
Post by rotbus19 »
See:
Could they be merged in to one?
Re: 2 x 'Adjust' context menus (almost identical)
by default there is no 'adjust' in context menu, so it seems that you have modified it in 'Settings>Context menu'
he means, there are 2 'Adjust [menus]' available for some reason
in Settings > Interface > Context menu > Viewer
cmd_adjustM
cmd_adjustM2
rotbus19
Post by rotbus19 »
xnview wrote: Fri Mar 01, 2024 10:26 am by default there is no 'adjust' in context menu, so it seems that you have modified it in 'Settings>Context menu'
Yes, I customised the context menu and there are two 'Adjust [menu]' available as shown in image (and by user0).
There should only be one? So merge the two shown?
oh right, there is 2 commands. one for menu without 'Auto *' and one for the toolbar with 'Auto *'
What is better:
- Move 'Auto *' from Map into adjust menu
- Keep 'Auto *' in Mpa and remove cmd_adjustM2
rotbus19
Post by rotbus19 »
xnview wrote: Sat Mar 02, 2024 8:28 am - Keep 'Auto *' in Map and remove cmd_adjustM2
Not sure what 'Map' means - but yes to removing cmd_adjustM2...
Move 'Curves...' from cmd_adjustM2 to cmd_adjustM then it will contain everything so cmd_adjustM2 can be deleted. :)
done in 170
