IPTC Editor = Insert
BuckSkin
Post by BuckSkin »
Currently using version 1.5.0
In the IPTC Editor, when I click the right-facing triangle at the extreme right end of each field, I get three menus, "Insert", "Insert From" and "Copy Into".
Insert From and Copy Into have always worked fine.
However, when I attempt to use the "Insert" menu, no matter what I choose, instead of getting that chosen text, I only ever get {embedded comment} or {XP Comment} or whatever, always just the { } containing whatever choice I have made.
Am I doing something wrong ?
Is there a trick to making this work ?
Thank you.
Re: IPTC Editor = Insert
Please use latest version
BuckSkin
Post by BuckSkin »
xnview wrote: Sun Feb 25, 2024 3:09 pm Please use latest version
I have installed the latest version and my results are the same.
No matter what I choose from the "Insert" menu, I only ever get my choice in brackets without getting the actual text.
For example, I choose XP:Comment and I get {XP:Comment}, not the text of the actual XP Comment
Thanks.
BuckSkin wrote: Mon Feb 26, 2024 7:58 am For example, I choose XP:Comment and I get {XP:Comment}, not the text of the actual XP Comment
yes, it's normal. The field will be replaced when writing.
BuckSkin
Post by BuckSkin »
xnview wrote: Mon Feb 26, 2024 9:34 am
I don't quite understand.
{XP:Comment} is shown, but when you write your IPTC, you'll have the correct value
BuckSkin
Post by BuckSkin »
xnview wrote: Mon Feb 26, 2024 4:47 pm {XP:Comment} is shown, but when you write your IPTC, you'll have the correct value
Thanks; that works.
Now, all the other values I have tested work as you described, except for
Insert > EXIF-Image > User comment
When I choose "User comment", I get nothing.
I was hoping that would be Embedded Comment from Edit Comment, but obviously it is not and I cannot find Embedded Comment as a choice in that menu; nor, can I figure out just what "User comment" is.
