Original
Pentaxi
Original
Post by Pentaxi »
Hi, How do you remove the _original version from the image in Metadata. What setting do I have on that makes it do that?
Takes up unnecessary space on the hard drive. Just a RAW file is enough for me.
Ja suomeksi jos täällä on suomalaisia:
Hei, Miten saa pois Metatiedoissa tulevan _original version kuvasta. Mikä asetus on minulla päällä, että se tuon tekee ?
Vie turhaa tilaa kovalevyllä. Minulle riittää pelkkä RAW-tiedosto.
mudo_j
Re: Original
Post by mudo_j »
I have noticed that using "Edit IPTC" on raw photos (without an existing sidecar file) makes ExifTool write metadata into the raw file (creating an _original backup, if set so), while it should, I suppose, only create a sidecar file. This might be a bug. "Edit XMP" behaves as expected.
Pentaxi
Re: Original
Post by Pentaxi »
Here is a picture of the file:
https://vilimijavalo.1g.fi/Valokuvat/XX ... hot.28.jpg
That "edit-xmp" makes the same extra _original file....
It hasn't helped either, I delete the whole program and download it again.
Byt should find a program that does that correctly.....suggestions?
Re: Original
please check 'Settings>File operations'
