1.6.4: It is impossible to remove some settings in the "File List" > "Format Colors" menu.
adrem85
Post by adrem85 »
For example, when removing unnecessary types of files and saving via OK, they are removed and when the menu is re-opened, they are not there. But after the restart of the program - they are there again...
https://www.upload.ee/files/16290685/Fo ... s.mp4.html
XnViewMP 1.6.4 x64 portable. Windows 11.
I would also like to add a couple of new features in this section:
1. I suggest adding the ability to delete not only using the REMOVE button, but also using the DEL key.
2. I suggest adding an option to separately save color settings for file types (File List - Format Colors). By the same principle as saving toolbar settings and hotkeys.
Re: 1.6.4: It is impossible to remove some settings in the "File List" > "Format Colors" menu.
no problem to save other settings in .ini?
adrem85
Post by adrem85 »
xnview wrote: Sun Feb 18, 2024 8:09 am no problem to save other settings in .ini?
Yes, all other settings are saved normally. The option to save the settings in the program directory is selected.
This problem is supposed to be fixed in XnView MP 1.6.5. Please check and confirm the bug fix here.
adrem85
Post by adrem85 »
I apologize for my long absence. Confirmed, problem solved, thank you! v1.7.0
