rename button from Optimize to Maintenance
as it opens Maintenance dialog
Suggestion B
regroup items in Maintenance dialog
rename OK to Run or Execute
clarify wording
not sure if there have been any changes since:
xnview wrote: Tue Jul 19, 2022 11:54 am
'Purge all thumbnails' remove thumbnails from database
'Purge file data' remove file informations from database, in this case thumbnail will be invalid too
but it looks like 'Purge file data' does not delete Images with Rating/Color<>0/Categories, not sure if it's desired behaviour.
Guess wording needs to be improved, eg 'Purge files w/o Catalog metadata' or 'Purge all files' (and delete all files)
Suggestion C
execute VACUUM after 'Delete all' button routine
Once all data is deleted from Xnview.db and Thumbs.db their size need to be reduced as well and its fast.
hm, Thumbs.db remains the same size (eg 5Mb) after "Delete all" for me
size is reduced (to 40 KB) only if one of the following actions is performed after "Delete All":
- Optimize database OR
- manual executing VACUUM, eg via "DB Browser for SQLite"
user0 wrote: Mon Apr 01, 2024 2:54 pm
I don't know why but sqlite doesn't want to execute VACUUM on thumb.db only on xnview.db
